Hey everyone. Ihope you can help me.
I have a problem with my pc, When i turn on my pc, i get the motherboard screen, then the windows 10 logo and then the sreen is black for almost 50seconds and then the login screen shows.   What should happen, and did happen upuntill 1.5days ago the windows logo showed and 5second later i was loged in.
All i have done in the last week that i can think of was installing some programs(Photo Below), Played Games, and i had to erase 3 HDDs and i did that by plugging them into my computer and erasing them with Disk Management.
I have atched a video of startup and a photo with programs i installed in the last week. I have tried to inclue all the info i can but if there is anything else i should show let me know.
Thanks
~ Grover
videoplayback.mp4
Intel Core i7-6700K 4.0GHz Processor / Cooler Master Hyper 212X LED Cooler / ASUS Maximus VIII Hero Z170 Motherboard / TeamGroup Nighthawk 16GB (2 x 8GB) DDR4-3000 Memory / OCZ Trion 150 480GB 2.5" Solid State Drive / 2x WDBlue 500GB 2.5" 5400RPM Hard Drive (Raid 0) / EVGA GeForce GTX 1060 6GB SC GAMING Video Card / Cougar Panzar Duel Window ATX Mid Tower Case / SeaSonic 520W 80+ Bronze Fully-Modular ATX Power Supply / Microsoft Windows 10 Pro
https://linustechtips.com/topic/759191-problem-with-computer-startup/
- Uninstall that recent program you mentioned
- Deactivate Autostart Programs not needed (Task Manager - Tab Autostart)
- Uninstall Antivirus Software and reinstall again
- Same with additional Firewall Software if any
I bet one of this will help as it does most of the time
oh i also installed team viewer and Pluralinput, but i uninstalled them later
This made it a little faster, but i found the problem. I have this 2nd monitor that i got this week and when its not pluged in my pc boots like normal. Idk why? it quite a old monitor that i found. but i never even though pluging in a monitor would give me a blank screen for 50second in startup.
I'v had other monitors pluged in before with no problems, so idk why i cant use this one..
Just now, ItsTheDuckAgain said:
that sounds strange though, would have never guessed that. can you reproduce by pluging it in again ?
Yes if i plug it in again i get the same problem. Any idea whats going on?
Hmmm, i pluged in my other monitor(i only have one cord), same make/model as the first one (i got 2monitors that a school were getting rid of) and i started up quickly... hmmm?
so 1 of the monitors works fine with my pc the other dosn't. Trying both monitors using a different computer, none of them had problems.
Tried different power and display cords, same result, one slows down my pc 50seconds and the other is fine.
What did linus call this??    Oh,    Haunted Hardware!!!!!   Aarrrrggghhhhhhh!
