This program is not running.It stops when I insert 1st element.The code is below.
#include<stdio.h>
#include<stdlib.h>
struct nod
	int data;
	int *next;
typedef struct nod node;
node *temp=NULL;
node *start,*newnode;
void insert ()
	int ele;
	printf("\n Enter the element ");
	scanf("%d",&ele);
	if(start=NULL)
		newnode=(node *)malloc(sizeof(node));
		newnode->data=ele;
		newnode->next=NULL;
		start=newnode;
		temp=newnode;
	else
		newnode->data=ele;
		newnode->next=NULL;
		temp->next=newnode;
		temp=newnode;
void display()
	node *temp;
	temp=start;
	while(temp!=NULL)
		printf("%d",&temp->data);
		temp=temp->next;
void main()
{	node * start =NULL;
	int ch;
	while(1)
	printf("\n Enter your choice ");
	printf("\n1.Insert ");
	printf("\n2.Display");
	printf("\n3.Exit");
	printf("\n enter your choice ");
	scanf("%d",&ch);
	switch(ch)
		case 1 :insert();
				break;
		case 2 :display();
				break;
		case 3 :exit(0);
https://linustechtips.com/topic/758751-linked-list-problem/
17 minutes ago, fizzlesticks said:
if(start=NULL)
Typo there. To avoid those kind of things it's a good idea to put the literal value on the left
if(NULL == start)
that way if you miss one of the '=' you get a compile time error instead of a runtime bug.
Thanks for the advice.I will keep in mind next time.
https://linustechtips.com/topic/758751-linked-list-problem/#findComment-9589699
