Hey guys, so I wanted to build my own PC soon, but Im not really sure what I should get.
So if you guys could help me out a bit and maybe create a few build for me or give suggestions, I would really appreciate it.
First of all, I dont know if Ryzen is worth it since I will mostly be gaming, ive seen they lack a bit of power in that regard.
These are some basic things u may want to know
Budget
Im willing to spend about 1700€ on my PC,
Peripherals needed, but no screen. Headset not really own one Thrustmaster Y-300CPX.
I already have a GTX 1080 Founders, so u can add that to the list.
I live in the Netherlands, maybe use this site https://tweakers.net/ since PCPartPicker prices are BS sometimes
Aim
My PC will primeraly be used for gaming;
BF1, BF4, Titanfall 2, R6 Siege, CS, and future games.
(It must be able to run Crysis 3  )
I will use my PC for 3D editing, 4k Photo and 1440p Video editing/Recording as a Hobby, so this shouldnt be taken in consideration too much.
Wanting to Future SLI and probz OC
Monitors
Having a single one and saving up for something like the 21:9, 100Hz ones.
Oh, and I do need Windows which is 120€ so lets say the budget is about 1600€
Thx for the Help!
(Repost, cuz I would like some more opinions)
https://linustechtips.com/topic/758408-first-build/
so is it 1700 euro excluding the GPU? or should we include it in the budget. if so how much did you pay for it?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/758408-first-build/#findComment-9585946
He said he is already having GPU and said to add the one to list. Simply just pick components without GPU for 1700 euros.
https://linustechtips.com/topic/758408-first-build/#findComment-9586045
