Question. Questions?
So... I'm using the QC (Quiet Comfort) 25 of BOSE and I want to know the kind of foam they use, and if there is any gaming headsets that is similar to this, or I should just stick to this.
Tell me the the preferred headsets and don't care about the budget as long as it is <$200 USD (I know I should have just typed budget is $200) :P
Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/
Planned Build PcPartPicker
https://linustechtips.com/topic/758332-question-questions/
I don't think "gaming headsets" are going to be nearly as luxurious at all. Bose uses some type of leather on their products, and the only pads I can think of off the top of my head that you could put on a headphone if they aren't as luxurious to you are Shure's SRH1540 pads - you can put those on just about any over-ear headphone.
https://linustechtips.com/topic/758332-question-questions/#findComment-9585157
