10 minutes ago, Stormegadan said:
My computer keeps crashing and giving me the stop code WHEA UNCORRECTABLE ERROR and I have no idea what is causing it. I've tried everything I can think of. This is seriously starting to become a major issue and I would appreciate the help!
Is it possible to send a picture of the blue screen?
https://linustechtips.com/topic/758199-blue-screens-please-help/#findComment-9583672
Is your windows fully updated?
Did you OC at all, (if you did reset the UEFI, as it may have something to do with the voltage).
What are the specs of the failing computer?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/758199-blue-screens-please-help/#findComment-9583675
Windows is fully updated and I did OC but I reset my bios. I'm running an i5 4690k, gtx 970, 16GB of RAM, Asus z97-e 3.1 Mobo, and windows 10 64-bit.
https://linustechtips.com/topic/758199-blue-screens-please-help/#findComment-9583710
