Its a h320 x2 prestige by swiftech, i wasnt brave enough to put the parts together myself so this seemed like a great way to get into custom water cooling.   I might eventually get a different CPU block and i will certainly be adding the GPU into the loop but i might wait till i next upgrade the card to do that.   As you can see i dont trust it at all even though i had it running for around 24h on the bench.  It was a pain in the arse but im really pleased with it.  6900k idles around 27 and only went as high as 33 while playing GTA5 for around an hour, next step is to overclock but im not in any rush to do it as it already has more than enough power.
https://linustechtips.com/topic/758123-my-first-custom-loop/
33C load temps, your room must be freezing to keep an 8 core 16 td chip that cool, I had this 4790k (88w TDP) on a 360mm and a 240mm loop and I never seen load temps that low, impressive if correct for a 140w TDP chip, what software are you using to monitor?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/758123-my-first-custom-loop/#findComment-9582748
