I was thinking of building a PC, not going to use OsX or anything just the case, any tips or is it just like any regular pc build?
Aim: Gaming and telling my pc owner friends that I bought a mac and it's really good
Have all of the peripherals and a monitor.
EDIT: I AM NOT GOING TO PIRATE A VERSION OF OSX
Reason for edit: Had to be typed in caps lock because people thought I was talking about pirateing and didn't read the txt.
https://linustechtips.com/topic/757410-2007-mac-pro-build/
I would remove all reference to "Hackintoshing" in your posts as its not allowed on LTT, You should just say that your building a Windows PC in a Mac Pro case.
Saying that your going to build a hackintosh means that you are looking to install OSX on PC Hardware so its safer to say your looking to do a Mac Pro Build :).
Anyways good luck with your build as getting a normal ATX Motherboard is a pain to fit in this machine.
Main Machine:  16 inch MacBook Pro (2021), Apple M1 Pro (10 CPU, 16 GPU Core), 512GB SDD, 16GB RAM
Gaming Machine:  Acer Nitro 5, Core i7 10750H, RTX 3060 (L) 6GB, 1TB SSD (Boot), 2TB SSD (Storage), 32GB DDR4 RAM
Other Tech: iPhone 15 Pro Max, Series 6 Apple Watch (LTE), AirPods Max, PS4, Nintendo Switch, PS3, Xbox 360
Network Gear:  TP Link Gigabit 24 Port Switch, TP-Link Deco M4 Mesh Wi-Fi, M1 MacMini File & Media Server with 8TB of RAID 1 Storage
https://linustechtips.com/topic/757410-2007-mac-pro-build/#findComment-9575490
2
Illogical. LTT did a Hackintosh video a while ago if i recall.
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/757410-2007-mac-pro-build/#findComment-9575499
The Mac Pro isn't a normal PC and its motherboard isn't based on any PC Standard, Heavy Modification of the case is needed to put any PC Standard parts into it.
https://linustechtips.com/topic/757410-2007-mac-pro-build/#findComment-9575503
You can buy kits which will make it easer to do but you'll still need to cut the case.
https://linustechtips.com/topic/757410-2007-mac-pro-build/#findComment-9575531
