So my parents downgraded our cable months ago and we've had absolutely garbage for channels because of it. I talked them into PlayStation Vue because it's the same price as what we're paying and we get a lot better choice of channels. Well, I bought the Roku streaming stick and it has trouble connecting to the router not more than 20feet away or even 15feet away. I bought a little net gear wifi extender and it works great with the Roku now. The tv is in their bedroom which is a good distance from the router and extender. Now laptops and other devices connect just fine, but the Roku antenna is garbage. Is their a better streaming device with a better antenna?
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/756755-streaming-tv-solution/
How'd you get best single core Cinebench on 4770K stock? Whats your clock speed?
https://linustechtips.com/topic/756755-streaming-tv-solution/#findComment-9568094
It was in general. I had a 4790K that did 5ghz stable at 1.33v. I have a 4770k that runs off of a stock cooler right now.
Main Rig
Plex Server WIP
https://linustechtips.com/topic/756755-streaming-tv-solution/#findComment-9568108
1 hour ago, Daniel Z. said:
wot 4790k @ 5GHz lucky.
Yeah 4.8 was stable at 1.22v
Main Rig
Plex Server WIP
https://linustechtips.com/topic/756755-streaming-tv-solution/#findComment-9568437
