I have this build in my mind and this is my first ever build.
https://pcpartpicker.com/list/sfrzjc
I settled with i5 since gaming is what I do and lots of people that I know suggested it. I wanna OC it aswell.
What do you guys think about this build? Willing to listen for better parts suggestion.
https://linustechtips.com/topic/756602-first-build-plan/
This one is really good but not overclockable
PCPartPicker part list: https://pcpartpicker.com/list/xLsy3F
Price breakdown by merchant: https://pcpartpicker.com/list/xLsy3F/by_merchant/
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  ($287.49 @ SuperBiiz)
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard  ($56.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory  ($99.97 @ Jet)
Storage: ADATA Premier SP550 240GB M.2-2280 Solid State Drive  ($69.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: PNY GeForce GTX 1070 8GB XLR8 Video Card  ($379.00 @ Amazon)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($45.98 @ Newegg)
Power Supply: Rosewill 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($64.99 @ Newegg)
Total: $1053.73
Generated by PCPartPicker 2017-03-23 13:14 EDT-0400
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566305
Just now, deXxterlab97 said:
It won't be stable or will be hot if you go further
ooh it can go further? Im happy with 4.2 if its not gonna hurt my proce in the long run. Main reason why I picked 67-k is because of 4.2 OC anyway. Anyway you're awesome sir. You replied on my other post aswell Thankyou.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566313
If you want overclockable ryzen then go with this
PCPartPicker part list: https://pcpartpicker.com/list/GpBNZ8
Price breakdown by merchant: https://pcpartpicker.com/list/GpBNZ8/by_merchant/
CPU: AMD RYZEN 7 1700 3.0GHz 8-Core Processor  ($324.88 @ OutletPC)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($99.99 @ Jet)
Motherboard: MSI B350M GAMING PRO Micro ATX AM4 Motherboard  ($79.99 @ Amazon)
Video Card: PowerColor Radeon RX 480 8GB Red Devil Video Card  ($214.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mini Tower Case  ($41.99 @ NCIX US)
Total: $1046.11
Generated by PCPartPicker 2017-03-23 13:19 EDT-0400
You can switch RX 480 with GTX 1060 if you want by spending 20-30$ extra.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566324
Total: $1053.73
@deXxterlab97 what do you think about this build? Sorry if I ask a lot.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566344
If you want overclockable Intel build then this one
PCPartPicker part list: https://pcpartpicker.com/list/mNzzjc
Price breakdown by merchant: https://pcpartpicker.com/list/mNzzjc/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($308.98 @ Amazon)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($59.99 @ Jet)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  ($69.99 @ Newegg)
Video Card: Sapphire Radeon RX 480 8GB NITRO+ OC Video Card  ($253.99 @ SuperBiiz)
Case: Corsair 200R ATX Mid Tower Case  ($44.99 @ Newegg)
Total: $1022.22
Generated by PCPartPicker 2017-03-23 13:23 EDT-0400
Actually 6700k is 40$ cheaper than 7700k which I think is not worth like its ok if its 15-25$ more but 40$! Then 6700k is the best bet you can really get a lot better performance than 7600k and it should be good for some content creation too. If you want you can switch RX 480 with GTX 1060 if you want.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566347
Total: $1022.22
Im more on gaming. But your suggestion made me think again lmao.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566367
Well 6700k is skylake but still is really good. Its OC capabilities are not bad either its really good. Your budget is around 1000$ and you made a list with i5 saying that you are into gaming but games are starting to utilise those extra 4 threads nowadays, so i7 is more future proof and still you are getting the same GPU. I mean I gave RX 480 but if you want go with GTX 1060. You can upgrade to kaby lake cpu which I say is not really worth as 6700k is still packing some serious power. You can get good OC with Corsair H60.
https://linustechtips.com/topic/756602-first-build-plan/#findComment-9566377
