Yes, but if it is higher than the supported mobo speeds, it will just lower to that.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
8 minutes ago, WhiteWhisps said:
I was buying a new motherboard and noticed different speeds. If say I was buying ddr3, will all ddr3 desktop memory fit and work regardless of speeds (Megahertz)?
faster the mhz will make gains  in ram intensive tasks iirc, not so much games, the max mhz supported by the motherboard is the highest the ram can run at. For instance i got sent 2400mhz ddr4, where my mobo only supports 2133mhz, so it always runs at 2133mhz
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
7 minutes ago, WhiteWhisps said:
So all ddr3 desktop memory is interchangable?
Pretty sure.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
