What's the label on the cable in the first picture?
where does it originate (a fan, the front I/O, etc.)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
it's from the cpu cooler, it's connect to the head. I already connected that one though, I'm wondering where the cpu fan connectors on the original case fans go ..? they're just connected to the cable thing on picture 5. the one that says "do not connect while pc is powered on"
your motherboard should have case fan headers. they're called SYS_FAN on your board.
I'd recommend plugging case fans into those headers.
Laptop:
so I just disconnect the 2 case fans from the cable on picture 5? and connect them to the SYS_FAN ports? what do I do with the cable that says do not connect while pc is powered on? do I just leave it their. thnx for the quick response !
yeah. disconnect from the cable in picture 5, and connect direct to the motherboard.
just leave the cable out.
Laptop:
I have everything connected and it didn't turn on . Could it be that I don't have a cord connected for the power button? on top of the case
16 minutes ago, SUPER_NANI_SKILLS said:
is their a connector that makes the power button functional?
there's supposed to be a two-pin plug called power SW (power switch)
plug that into your motherboard, where the power switch is supposed to go. (different on every mobo, check manual.)
Laptop:
