Hi guys, I am planning to build myself a PC. I was hoping to ask your help (and experience) on spotting potential bottlenecks or incompatibility. Here's the setup:
PROCESSOR : i5-6600k
MOBO: MSI B250M Mortar
CPU Cooler : CM Hyper 212x
GPU : GTX 1070 G1
PSU : Corsair CX500M 80+ Bronze
RAM. : DDR4 SODIMM Crucial 1 x 8Gb 2133mhz
Case : nZXT S340
Extra coolers : 2x 120mm Fans
HDD. : 1TB + my old HDD (will get an SSD Later, can someone point me to the right direction?)
DVDRW: ASUS 24x
Your help will be very much welcome. Thank you!!!
The build is around the GTX 1070.
https://linustechtips.com/topic/755412-asking-for-help-on-pc-building/
First of all, you can't use SODIMMs on desktop boards without an adapter
You don't need a Hyper 212X on a B250 board, go for 6700 locked and a cheaper board.
Get a better PSU, Seasonic S12ii as an example.
Where are you located if I may ask?
idk
Just now, Dale Sumala said:
Thanks for the quick response.
I will be using it for some 3D Stuff like CAD, Solid Works and CATIA (I am an engineering student)
And I will also be using it for Gaming ofcourse.
@nerdslayer1 Can help, he is also in engineering
If you're more focused on Eng. works, then go for some Ryzen CPUs which will compromise gaming performance a bit, but if you cannot compromise on gaming, then you'd be compromising rendering on those soft.
-- BSOD : ( --
1 minute ago, Dale Sumala said:
Thank you Sir.
Could you recommend a RAM?
I just need 1 stick of 8Gb for now and will upgrade later when the need arise.
Look around, find the cheapest 8GB stick you can. Brand doesn't matter, the chips come from the same place anyway
idk
Thank you Sir.
- 6700 or a 6700k
- another 8gb ram stick
or build a new computer with ryzen cpu, if you multitask alot with program like cad it will take some horsepower.
For now, I am inclined on doing the following :
Procie to 6600
MOBO to "cheaper"
Adding another 8Gb stick of ram
       Or
         SSD if not the extra RAM(if I still got the budget)
I'ld LOVE to try RYZEN. But I am unfamiliar with AMD this past few years I wouldn't know how to utilize them.
I'ld like to remain on the comfort zone or reliable/proven/tested Intel. Since I am gonna  use it for school
Chances are, I will not OC in the near future.
Procie to 6600
MOBO to "cheaper"
       Or
get a 6600, cheap mobo 16gb ram. yes 1700 is overkill for your needs.
8 minutes ago, nerdslayer1 said:
mechanical engineer, i am working in an aerospace company.
Wow! You're like William Nye then? Bill Nye the science guy?
I am an Aeronautical Engineering student. Someday I hope I could work for Aerospace too. Or NASA :)))
So I've found this really cheapo RAM KIT
"Geil Super Luce" with 2x8GbS and 3000mhz while still cheaper than avarage 4Gbs 2444mhz kit. Is this good
With the motherboard if your are using a 6th gen intel you can use a 100series chipset (h110, b150, z170 etc) it maybe cheaper
Desktop: Cooler Master MasterCase 5 | i7 6700k @4.7GHz 1.3v | Custom EKWB soft-tubing loop (CPU + GPU) (2x 240mm Alphacool rads)| Zotac GTX 1080 Founder Edition | Asus Maximus VIII Hero Motherboard | Samsung 850 EVO 512GB SSD | 4TB Seagate HDD | 2TB Seagate HDD | EVGA SuperNova G2 750 | Acer Predator XB271HK | https://uk.pcpartpicker.com/list/xzjRHN
Can you recommend a cheaP SSD (for boot drive)
Have you tried looking on pc part picker?
