Hey everyone, i am new to the building a PC world and have no idea what exactly i need. Ok so background. I do alot of AutoCAD work and ESRI work with ESRI i do alot of map creations with decently sized files. I would also like to game on this PC and at some point be able to upgrade to VR. I have 2 basic monitors but will upgrade them as needed. budget is around $1500 USA. upgrading because my current dell takes forever to render the maps and is really laggy when i have to rotate the image. Thank you.
https://linustechtips.com/topic/755116-first-build-pc/
6 minutes ago, Jeepman95 said:
-SNIP-
Everything you want, plus VR capable already
Very powerful i7, make a breeze out of AutoCAD and ESRI
http://pcpartpicker.com/user/UberGamerKing/saved/GTLHxr
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/755116-first-build-pc/#findComment-9549304
1 minute ago, UberGamerKing said:
He doesnt need a 1080 when hes mainly doing CPU bound stuff
it doesn't hurt,
a 1700 kills a 6800 in creative work such as photos, video and cad.
https://linustechtips.com/topic/755116-first-build-pc/#findComment-9549308
How about this one
PCPartPicker part list: https://pcpartpicker.com/list/PVFNZ8
Price breakdown by merchant: https://pcpartpicker.com/list/PVFNZ8/by_merchant/
CPU: Intel Xeon E5-2620 V4 2.1GHz 8-Core Processor  ($407.89 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($151.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-3000 Memory  ($189.97 @ Jet)
Storage: ADATA Ultimate SU800 128GB 2.5" Solid State Drive  ($44.99 @ Newegg)
Storage: Hitachi Ultrastar 7K3000 3TB 3.5" 7200RPM Internal Hard Drive  ($79.49 @ Amazon)
Video Card: Asus GeForce GTX 1080 8GB TURBO Video Card  ($488.98 @ Newegg)
Case: Corsair Air 540 ATX Mid Tower Case  ($121.99 @ B&H)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($61.89 @ Newegg)
Total: $1572.06
Generated by PCPartPicker 2017-03-20 13:36 EDT-0400
https://linustechtips.com/topic/755116-first-build-pc/#findComment-9549346
or how about this one
PCPartPicker part list: https://pcpartpicker.com/list/Vx9mJV
Price breakdown by merchant: https://pcpartpicker.com/list/Vx9mJV/by_merchant/
CPU: Intel Xeon E5-2603 V3 1.6GHz 6-Core Processor  ($197.28 @ Jet)
Motherboard: Supermicro MBD-X10DAL-I-O ATX Dual-CPU LGA2011-3 Motherboard  ($301.98 @ Newegg)
Memory: Samsung 32GB (1 x 32GB) Registered DDR4-2133 Memory
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $1556.74
Generated by PCPartPicker 2017-03-20 13:51 EDT-0400
It is total 12 cores and Windows 10 supports 2 CPUs
https://linustechtips.com/topic/755116-first-build-pc/#findComment-9549398
1 hour ago, M.A.P said:
How about this one
Total: $1572.06
That cpu doesn't make any sense. The Ryzen R7 1700 is cheaper/faster.
https://linustechtips.com/topic/755116-first-build-pc/#findComment-9549662
