CPU temperature oscillating
Completely fine. It varies to much because your CPU speed is changing its speed all the time...
Your CPU under low load, will declock MHZ to 800mhz when not doing much..... UP TO the boost clock when you push it.
When its low mhz (under 1-3Ghz and below), your temps go down to typical idle temps, when PC requires more power, the CPU clocks to Max it can and temps follow suit.
In any couple of seconds at any time,..., your CPU can flux its frequency many times. (It has sensors detecting many things) and the corespeed changes frequently. This is all normal, happens to everyone, and is of no concern as your temps are also fine and within "typical" usage findings.
Around 25-40*c Idle temps (depending on where you live in the world, and current airflow/cooling potential) are normal.
