Decent monitors for future reference.
Go to solution Solved by Guest,
57 minutes ago, Aphexxis said:
500 (English pounds)
JBL LSR305 then. Tough to find a more accurate monitor for the money. Or more money, even.
In the near future i want to significantly upgrade my speakers to something high grade and transparent.
I would like some advice please.
@SSL @spwath
Stuff like this for example.
https://www.amazon.co.uk/Audioengine-A2-Powered-Desktop-Speakers/dp/B00DQMJE7E/ref=pd_sbs_23_8?_encoding=UTF8&psc=1&refRID=DZKQ1DPQKKYTHDV34KY9
And when i do, will i need to upgrade to a dedicated sound card?
I have a intel xeon cpu and a 1070 i hope this makes you salty.
https://linustechtips.com/topic/754355-decent-monitors-for-future-reference/
@Aphexxis
FYI, I would highly recommend using a sound card with monitors. Depending on your usage, it will be really useful. Additionally, you will definitely be able to hear a great sound difference, even if you get a 'cheap' (it's all relative) model.
I haven't looked at what @SSL recommended in depth, but I would definitely buy a sound card with monitors if I didn't have one already.
If you can get 2 of the monitors for a total of ~250 pounds, you could look at the Komplete Audio 6, which would fit in your budget. It is a very decent sound card, isn't too expensive, and rather small. Again, if you have any ideas/preferences, tell me and I'll help you.
3 minutes ago, Sneling said:
@Aphexxis
It's a good monitor. The main benefit to the interface (what you reference is not a "sound card") would be the balanced outputs.
Yeah ok. Thanks for the precision, I always assumed they were basically the same (one was internal, the other external, but nowadays interchangable).
Part of it is the use case; an interface is a professional device, whereas a soundcard is what Asus and Creative make these days.
For example, stuff made by the likes of Lynx, ESI, etc, are PCI cards, but still referred to as interfaces.
