So, I've been planning this build for a few months now and nearly have enough money saved. I kept switching out components and adding things until I came up with this. The theme typical is red and black. My budget was €1500 but as you can see, that didn't go to plan. This is going to be my first build. It's (obviously) going to be a gaming PC used for 1080p gaming until I can get a 1440p monitor. My goal was to make it fairly future-proof and VR-Ready. Any suggestions on ways I could make it cheaper without compromising too much would be appreciated. Also, just suggestions and thoughts in general too.
https://de.pcpartpicker.com/list/FkY79W
https://linustechtips.com/topic/754173-thoughts-on-build/
8 minutes ago, deXxterlab97 said:
You can get a cheaper SSD. Literally no difference
Seagate Barracuda HDD is cheaper
S340 Black/Red non elite?
Don't activate Windows 10 to save ~130 euros?
Cheaper motherboard maybe?
Thanks! I'll probably look for a cheaper mobo
https://linustechtips.com/topic/754173-thoughts-on-build/#findComment-9539350
Looks pretty good!
I would get a monitor with a higher  refreshrate and as @TheBloodedEagle said, cheaper storage is possible.
also, I would wait and see the benchmarks for Ryzen r5, and probably get 1500x or 1600x (depending on what you want to use the PC for) and maybe aio cooling like the corsair h100/110/115i for better overclocking (if you don't plan to overclock, don't get Ryzen, and go for air cooling
https://linustechtips.com/topic/754173-thoughts-on-build/#findComment-9540248
