SEAGATE Portable drive problems
Solved by RandomFlipper,
5 hours ago, Praxis said:Depending on the warranty you could always try returning it, so long as you've got somewhere to store the files until you get a new external drive.
Western Digital's Red drives are specialised for RAID setups. If you're not going to use RAID for backup and are just going to set up a manual backup or use it similarly to a external drive you can save yourself some money by going with a WD Blue or Green. Those drives are normally cheaper.
Thanks for the advice!
