Loud Airflow
Solved by KeemoSabe,
Yes! Easiest way to do this is to access your motherboard fan controller and reduce the RPM to your acceptable noise levels.
Another way is to add rubber rings to the screws to reduce vibration.
Featured Topics
kodokuj ·
Posted in Graphics Cards0 -
.HEXY ·
Posted in Graphics Cards1 -
5
Dedayog ·
4
4
mbecker ·
Posted in Peripherals2 -
Prajnaanicca ·
5
3
