Suggestions for temperature control.
6 minutes ago, 266947_1454182200 said:I originally had it on the front but the gpu hit 99deg so I moved it. I knew the cpu could take the higher temps.
I Just played about an hour and a half of Shadow of Mordor. The hottest my cpu got was 76 and 80 on the gpu. So the cpu temps have dropped around 10deg on average. I'm not sure if this AS Ceramique has any cure time or not so it may drop further.
I am also thinking about swapping my AF140q intake fans for ML140 fans in the near future.
Yeah Ceramique has about a 25 hour cure time with several thermal cycles to fully cure per Arctic Silver's website so it should only get better lol.
That sucks that your GPU suffered as a result of the positioning. Maybe that's your queue to water cool it too ![]()
