Have you been able to play it before?
I think a possible fix was to run Origin in Administrator mode and then repairing the install. If that doesn't work, try reinstalling the game while still having Orign in Administatro mode.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/75312-directx-problem-bf4/#findComment-1032127
Also in the BF4 downloads folder check for a folder called "_Installer" > Directx > redist  and then run DXSETUP.exe
okay thank you im gonna try it out
https://linustechtips.com/topic/75312-directx-problem-bf4/#findComment-1038241
