My PC's Audio Jack
Go to solution Solved by Guest,
Looks like a software problem to me, if you're on Realtek Audio manager, just change the default device from there or from windows setting, you'll find pretty much everything there which would help you fix it.
2 minutes ago, EasonIDontKnowAnything said:
So you guys know that your pc's front has a audio , mic , and usb ports. But The Audio Port when I plug in my headphones I can only hear music , or NOTHING at all.
Make sure the front audio connector is plugged in properly to the MoBo and make sure your headphones work on other devices too as it could be that
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/753088-my-pcs-audio-jack/#findComment-9528041
It's working fine now thanks to ur help. But I had to twist the headphone jack thing at just the right spot to hear the voice and music
https://linustechtips.com/topic/753088-my-pcs-audio-jack/#findComment-9528135
