hey guys my mum dropped her s2 on the floor and broke the whole screen so i have to set her up a new phone. Is there any way to retrieve contacts when you like plug the phone into a computer or are her contacts etc pretty much impossible to get back
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/75232-galaxy-s2-help/
They may be stored on the sim card, if not you should be able to get it from the phone.
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030836
doesn't seem to be on the sim :c ill have to play around with it
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030841
hmm if you open the phone's content on your PC you should be able to find it in the application data, it could be stored alongside your applications
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030846
i'll have a look now
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030854
If you use the Kies software you should be able to back it all up onto the PC, then restore on the new phone (presuming you/she gets another Samsung).
MAXIMUS VII HERO | i7 4770K w/ H100i | 2x8GB 1600MHz | GALAX GTX 970 x2
250GB SSD boot | 250GB x2, 1TB SSD storage | Corsair 400C | Corsair RM550
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030879
iphone :c
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030894
iphone :c
Huh..... Alright, well the next best bet would be to extract the contact info from Kies (hopefully) then manually type the contacts into the iPhone...
Or try some of the suggestions in the comments of these threads:
http://www.makeuseof.com/answers/import-samsung-kies-pc-suite-contact-spb-file-iphone/
https://discussions.apple.com/thread/4301342
https://linustechtips.com/topic/75232-galaxy-s2-help/#findComment-1030907
