Im trying to find the difference between these two. Unless I'm dumb I dont see a single difference. The only difference is one is noted as V2 with a different model code but theyre the same price. HALP my brain hurts.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/752306-pump-modkit-difference/
One of them says V2? Aside from that I can't really tell them apart in any other way
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/752306-pump-modkit-difference/#findComment-9519500
well that was my conclusion at first but why?
https://linustechtips.com/topic/752306-pump-modkit-difference/#findComment-9519508
Looks like they made a revision for one reason or another could be just manufacturing or a small change in the part. Visually though from the photo I don't see a difference.
https://linustechtips.com/topic/752306-pump-modkit-difference/#findComment-9519754
