Hello,
So, having just ordered an Rx 460, I would like to know what I should purchase for a riser cable to go with it, It does require external 6-pin power if that matters any.
I already do have a non-powered one, but I do not trust it enough to use with this card after what it did to my R7 240, even if all the connections look fine on the PCB.
My procrastination is the bane of my existence.
I make games and stuff in my spare time.
https://linustechtips.com/topic/752226-riser-cable/
Why would you purchase a riser cable? It's not like you need it or something...
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518689
It's for a custom build I'm working on that involves the installation of a full system inside of a briefcase.
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518702
If you want to spend as much money as you spent on your GPU on a riser cable, by all means, do it. But IMO, it is not worth it....
A good riser cable costs $100
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518719
Yeah, there's no way I'm spending that much on one. All I really want is one that wont kill a graphics card. hence why I'm looking for recommendations
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518728
No PCIe Riser will kill your graphics card. But many will cause weird issues...
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518735
Well, in that case I must've gotten a defective riser.
https://linustechtips.com/topic/752226-riser-cable/#findComment-9518908
What do you mean....?
https://linustechtips.com/topic/752226-riser-cable/#findComment-9519339
I used it to connect my R7 240, and it worked well for about half an hour before suddenly my PC crashed, I rebooted and the card wouldn't power on, even when connected directly to the motherboard, no video output, nada.
I contacted the manufacturer and they stopped replying to my emails.
https://linustechtips.com/topic/752226-riser-cable/#findComment-9519358
Yep. The riser was faulty... You can't get a good one, unless you spend $100+.
https://linustechtips.com/topic/752226-riser-cable/#findComment-9519431
Is this the same case for 90 degree adapters?
https://linustechtips.com/topic/752226-riser-cable/#findComment-9521045
Idk.... But I think that it is not...
https://linustechtips.com/topic/752226-riser-cable/#findComment-9523199
11 hours ago, yawacool said:
  Hide contents
You can refer to this
http://cryinginthenight68.wixsite.com/liheat
This site has been mentioned
According to PCIE power specification
X16 25W ~ 75W (5.5A)
Your R7-240 has no extra power
Not suitable for PCIE cables
I upgraded to an RX 460 that requires 6-pin power yesterday, my specs list has been inaccurate until just recently.
https://linustechtips.com/topic/752226-riser-cable/#findComment-9528358
