I know there is a hotly debated topic of blower vs open shroud but i have not seen a Founder or reference blower vs an after market blower discussion before.  Is there a difference?
Example  both are clocked the same so why make 2 different products if the turbo doesn't cool better.  (I do see that the turbo has a DIV port on it)
Asus Founders 1080 ti
https://www.asus.com/us/Graphics-Cards/GTX1080TI-FE/
Asus Turbo
https://www.asus.com/us/Graphics-Cards/TURBO-GTX1080TI-11G/
https://linustechtips.com/topic/751769-reference-blower-vs-aftermarket-blower/
The Turbo has a DVI Port, which could mean it has a Custom PCB. Founders is always going to be the same PCB, Layout, etc as other card manufacturers for those wanting waterblocks etc.
This could be why this card exists. It could be a non-reference PCB in blower style.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
Aftermarket cards will always be better however reference cards do have their advantages like finding water blocks is much easier and if you have a small form factor case that doesn't have much airflow reference cards will be better.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Founders is always going to be the same PCB, Layout, etc as other card manufacturers.
I guess that would be a reason to have the different produce but what about the cooling and OC head room?  I guess that is what I am really getting at.
For cooling is this true for aftermarket blower style cards too?
Aftermarket blower cards will be on-par with reference in fact most aftermarket blower cards use the same PCB as the reference version.
زندگی از چراغ
  • 2 weeks later...
I know this topic is old but I am interested in aftermarket blower cards. But this shows that the ASUS' blower design is much worse than Nvidia's design.
ASUS tends to be overpriced and underdeliver (they have one of the biggest 3-fans cards for GTX 1080 but it runs hotter while producing more noise compared to other smaller 3-fans cards or even 2-fans), so I am not certain if this represents every aftermarket blower designs out there for Pascal GPUs atleast.
Edited by ApolloFury
fixed spelling
I don't read the reply to my posts anymore so don't bother.
