Hey all,
So it has been a very long time since actually upgrading my computer (last time was when dual cores were just coming out). I don't game much on my computer that often as I have consoles for that, but there are some games that I wish to play but unfortunately do not have a computer good enough for it. Games wanting to play include: Cities Skyline, Civilization 6, Stardew Valley and the like. Not much into the FPS games just RTS or RPG games. I will probably only be gaming in 1080P as that is the current monitor that I have, but maybe down the road upgrade to 1440, I don't see going to 4k. I have been looking at some of the new developments (and there have been many) in the field and have put together a rough build as to what I think I am looking for. I have a budget of approx $1200 to $1500 Canadian (I live in Canada). Was looking for a second opinion (as to if this is overkill or not) and clarification on some questions.
Here is the Part list: https://ca.pcpartpicker.com/list/QWjcjc all to fit in this case: http://www.corsair.com/carbide-series-spec-alpha-mid-tower-gaming-case-white-red
Some of the questions:
  1. Is the processor overkill? I don't need a unlocked one (as I don't overclock or know how to), but wondering if the 7500 would be better for some savings.
  2. I like the idea of a water cooled CPU, but again not sure if it is really worth it or if I should stick with the stock cooler.
  3. I currently have a SATA 3 SSD and 2TB HD in my PC. I was going to reuse these but wondering if the SSD should be upgraded as it is only 60GB and full already.
  4. Is an M.2 drive worth it as a boot drive, or should I compile the SSD and M.2 and just get a bigger SSD?
  5. The graphics card should be good enough for what I need it for and I don't see myself spending $500+ on a new one especially because I am getting a whole new rig.
  6. The PSU, is this too much? Should I decrease it?
Thanks for helping me out!
https://linustechtips.com/topic/751330-help-with-a-new-build/
aio on non OC cpu?
why 2 ssd's
sfx psu's are really small
everythin else is fine
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508310
Just now, CatXice said:
aio on non OC cpu?
read the whole post - OP has stated that as one of his/her questions
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508314
a CM 212 evo woudl run it at 55-60c under load i have one on a 7600k on stock clocks at 60c under load y get a aio and run it at 30c theres no point
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508319
2 minutes ago, CatXice said:
aio on non OC cpu?
why 2 ssd's
Not sure what the first part is referring to.
I just put the parts in there for the SSD as I am unsure as to if getting an M.2 was worth it or if I should get a larger SATA SSD.
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508321
m.2 is faster but in real terms u will see next to no difference and the green pcb will look ugly
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508323
https://ca.pcpartpicker.com/list/gsf8Cy
i changed the psu to a atx 1 and then money u save is the difference of the 7600 to the 7600k in fact its cheaper win win
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508332
You can get covers (I agree theyre ugly as shit) I got one from some place in Portugal, you can see it in the top of this picture:
available here:
http://www.coldzero.eu/364-m2-covers
10 minutes ago, DRHov3y said:
Hey all,
1) I'd go with an i7 7700 (non k) - You had a z series board with a non k CPU, basically not required
2) No need to water cool a non k CPU, a nice air cooler will keep temps and noise down for less money
3) Keep the 2TB drive, 60GB SSD not worth keeping
4) m.2 is nice, I barely notice the difference on mine - just get a bigger SSD
5) 1060 is pretty good, 480 is better and will get better with more driver updates
6) PSU was OK, I switched to EVGA for less $$$
CPU: Intel Core i7-7700 3.6GHz Quad-Core Processor  ($389.98 @ DirectCanada)
Motherboard: ASRock Fatal1ty H270M Performance Micro ATX LGA1151 Motherboard  ($156.95 @ Vuugo)
Memory: Team Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg Canada)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($179.98 @ DirectCanada)
Storage: Western Digital Black 5TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: Asus Radeon RX 480 8GB ROG STRIX Video Card  ($294.50 @ Vuugo)
Case: Corsair SPEC-ALPHA ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($108.98 @ DirectCanada)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($115.76 @ Vuugo)
Total: $1366.14
Generated by PCPartPicker 2017-03-12 16:17 EDT-0400
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508343
the build i posted will be a lot better long term
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508358
15 minutes ago, DRHov3y said:
Hey all,
Echoing most other people:
1. Get a 7600K, is definitely worth the $20 extra
2. As long as you don't try to run a crazy overclock and want to save a few bucks, a Cryorig H7 or Hyper 212 EVO are both cheap options
3/4. Just buy a larger SSD and drop the M.2
5. Get an RX 480, they run a little better and all signs point to them aging better than the 1060. Plus, you get an extra 2 GB of VRAM if you switch to 1440p some day
5. Wattage is fine, but get an EVGA non-SFX (cheaper and more reliable)
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508362
Why?
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508376
Just now, stealth80 said:
Why?
cheaper and 7600k not a 7600
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508380
But I have listed 7700 not 7600 ... aka i7 not i5 also you're neglecting OP's requirements:
Doesn't know how/want to overclock
You also left the build wit h2x small in-needed SSD's go with 1 large or a large SSD + smaller m.2 boot drive - but budget doesn't allow the latter option
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508386
can oc in future if wanted to and its cheaper then what he posted first calm down bro
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508393
I am calm lol, but I don't see how an i5 is better long term than i7
Its also more expensive than the OP's build
My point is you just discounted my build and said "mines better long term" with zero reasons why - aka cause you can overclock or it has more hard drive space, can have crossfire etc etc
and I think you're wrong, the i7 would be better long term for someone unwilling to overclock :)
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508421
i didnt see yr build at all i was talkin about mine vs his and he didnt add his case which i did at £75 if u bothered checking :D
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508430
ahhhh fairy snuff xD
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508440
dude u cant run a 7700 on a stock cooler it will boil under load i mean u can but it will not like it
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508448
hmm hm, but it's also $130 under budget so OP can add air cooler or AIO - OP's choice
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508457
u changed his gpu and ram the ram is questionable i mean i would never buy ram from a non mainstream company and changed the card to save £50 so u know and u cpu is boiling and i have heard bad things about as MB idk how true it is but u know
My Build
i5-7600k
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508467
Hell ye I changed the GPU, 480 is a better card long term, we know that. 7700k gets hot when pushed to 5ghz, its a vanilla 7700 running 4ghz on 4 cores or 4.2 on 1, it won't suffer the same issues, but as you insist:
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($63.98 @ DirectCanada)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($129.99 @ Newegg Canada)
Total: $1440.12
Generated by PCPartPicker 2017-03-12 16:56 EDT-0400
Ryzen Ram Guide
https://linustechtips.com/topic/751330-help-with-a-new-build/#findComment-9508513
