PSU for computer running 24/7
Go to solution Solved by RadiatingLight,
Tier 1 and 2 are great. tier 3 is fine too.
Just make sure you get a PSU that falls into that category.
also, minecraft servers aren't that intensive, so you could get by with a tier 4 if you really needed to, as the PC won't be at 100% load.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
