So I've decided that my current PSU can't sport the 1080 with a i7 6700 so I wanted to upgrade to possibly a 750 watt or a 600 watt and I don't know what to get I also want it to be under about 150 bucks and I don't care if it's modular.
Please @Dormant God or quote me if you want me to see your message/reply
        Custom PC Specs
Custom PC Build: (CPU) i7-6700k (MotherBoard) GIGABYTE G1.Sniper Z170 SLI ATX (RAM) 16 GB Dual Channel DDR4/3000MHz (GPU) MSI GTX 1080 (Case) Crystal 570X RGB (Storage) 1 TB HDD from Seagate
https://linustechtips.com/topic/750571-need-help-with-psu/
What is you current PSU
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500523
It's a 400 watt that is all I know and it's non-Modular
        Custom PC Specs
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500526
1 minute ago, EnemySp0tt3d said:
evga g2/g3
This and Only this
l i7 5930k | Rampage V Extreme | Corsair H110i GTX | G.Skill Ripjaws 4 16GB DDR4 3000Mhz | EVGA GTX 1070 Superclocked ACX 3.0 | EVGA SuperNova 750w G2 | Samsung 960 Evo 250GB l Samsung 950 Pro 256GB | Samsung 850 EVO 250GB | Samsung 840 EVO 250GB | 1 TB WD Red | Corsair 900D |
Evolution - https://uk.pcpartpicker.com/list/LbJq9W
CPU-Z Validation - http://valid.x86.fr/3dxmew
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500527
If I get this does it come with the needed cables or do I have to get them?
1 minute ago, RxL said:
3 minutes ago, EnemySp0tt3d said:
evga g2/g3
This and Only this
        Custom PC Specs
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500539
This and Only this
That or a Seasonic X-series, Snow Silent, Prime, Platinum, Fanless, SSRM, etc.
That or a Corsair RMx, RMi, HXi
That or a Cooler Master V-series
That or an XFX XTS, PRO, etc etc etc
A Seasonic X-series 850W can be found for $108 dollars on the internet somewhere if you want a steal but the EVGA GQ/G3/G2/GS/B2 all satisfy your need. The Corsair RMx is also a solid option as well as the Cooler Master V-series which seems to be tumbling in price on a few parts of the internet whenever I check.
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500542
The PSU comes with all cables needed since it is modular and you even get a Jumper block inside for when you want to run the psu without needed to power the motherboard or other parts
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500543
I think I'm going to get a G3 750 watt Modular
5 minutes ago, RxL said:
        Custom PC Specs
https://linustechtips.com/topic/750571-need-help-with-psu/#findComment-9500551
