Hey guys, So I went ahead and ordered a bunch of parts for a new build. I was planning on doing a water cooled 350D But last night, Linus got me thinking with the Arc mini Review. I have a few questions regarding the 350D. Can I remove the optical drive cage? And anyone with the case, Have you been able to Stash away SSD's Behind the Mobo tray or any other place that keeps them out of sight? If not, I think Im going to go ahead and grab the Arc Mini.
https://linustechtips.com/topic/75034-matx-problems/
Yes you can remove it.
Yes you can put SSD's behind the MB tray. http://img.hexus.net/v2/chassis/Fractal/ArcMidiR2/midi-04b.jpg on the right, holes for 2 SSD's
Or you can gecko Velcro them.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/75034-matx-problems/#findComment-1027842
I would say yes to ssd mounting on back of mobo tray, looks enough clearance, don't know about ODD though cant see if they are rivets or screws, presuming screws.
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
https://linustechtips.com/topic/75034-matx-problems/#findComment-1027852
Thanks for the replies guys! I love the look of the 350D and Im glad I can stash away some SSD's But I cant get over the fact I can use a 360mm Rad in the Arc Mini. I got some thinking to do :P
I have the 350D myself, and if I were to water cool, I know you can remove the rivets holding the 5.25" bays. I already have my ssd attached to the back of my motherboard tray inset that's holding the PSU with double sided tape. I'd stick with the 350D! It looks awesome and the you probably won't need anything more than a thin 240/280 in the top and a thick 240/280 in the front to cool a CPU and even 2 GPUs.
https://linustechtips.com/topic/75034-matx-problems/#findComment-1028397
