Old(ish) system overclocking advice
Solved by Skiiwee29,
10 minutes ago, ant666_2 said:if i where to invest in a 212 evo would that help things? i could use all the proformance i could get as i cant afford an upgrade yet
no, not really. The chip is very bad for gaming.... You are still only going to gain the very few FPS on this chip as I have mentioned above regardless.
