So i'm planning a build with an 1800X as I want the extra threads, sick of dropping frames while streaming + I generally run lots of things at once (I have 3 monitors, so I typically run a game, OBS, Skype/Discord, 100 google chrome tabs. sometimes multiple games at once)
I want this build to have premium components, by that I mean it's well balanced in the sense that everything is top end (That doesn't mean i'll be buying a 6950X and 4-way SLI 1080Ti's)
Here's what I've got so far : https://uk.pcpartpicker.com/list/BqXKM8
1800X, Vega's top end card (whatever it is when it comes out, it's already been shown playing DOOM and Battlefront at 4k with 70FPS)
Crossair VI afaik is the top-end Ryzen motherboard, I like the TridentZ RGB RAM and it's got enough speed to keep the 1800X fed, and I've got an X62 so I can try clock the 1800X to 4GHZ or higher if i'm lucky.
Not sure about the PSU - I have a RM550X at the minute but I'm not running a massive OC and i'm not SLIng anything so hard to judge how good it is.
As for the case, S340 elite seems fine, I was considering the Corsair Crystal 500X RGB but from the reviews I read it's garbage but looks nice, any other recommendations for a nice, not too big case with tempered glass and decent features?
Let me know what you think of the build and if I should change anything.
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/749865-ryzen-1800x-build/
7 minutes ago, deXxterlab97 said:
You put the wrong link
Updated, thanks!
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/749865-ryzen-1800x-build/#findComment-9492683
If you use all the programs you mentioned simultaneously, including OBS, sometimes multiple games, streaming, a metric shitton of chrome tabs and more you might consider going with 32gb of ram. Just a suggestion, but if you want the best and you want it to last a bit I would personally go with 32gb :)
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/749865-ryzen-1800x-build/#findComment-9492733
17 minutes ago, deXxterlab97 said:
note that mx300 is not an nvme
Didn't know that. Explains why it's so cheap. I'll go with the sandisk one
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/749865-ryzen-1800x-build/#findComment-9492812
I think 16GB is enough for me. I rarely go over 12.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/749865-ryzen-1800x-build/#findComment-9492846
I would go with the R7 1700 or R7 1700X over the more expensive 1800X. You should get a good overclock on that Asus board.
Also be aware that you need a mounting kit for the AM4 socket as AM4 isn't backward compatible with AM3+. You can request one from NZXT.
And Ryzen has/had issues with high frequency ram. Not sure if this has been addressed yet. I would personally go with 2400MHz - 2666MHz.
If you only plan to run a single gpu then your RMx 550W is enough.
https://linustechtips.com/topic/749865-ryzen-1800x-build/#findComment-9496558
