Need help choosing a new PC Casing
Go to solution Solved by Skiiwee29,
5 minutes ago, Belbs said:
What case do I have right now?
Idk. Its brand is 'rise'
How many fans are in the case and how is your air flow?
ne on the back and one on the side. the side one is blowing in and the one on the back is blowing out and I feel like it's not enough as my stock cpu cooler makes lotsa noise even if I just cleaned it and the heatsync and added new thermal paste. also just recently upgraded my gpu and I feel like it's the cause altho not sure
Can your case and motherboard/power supply support additional fans in the case to move air around?
nope that's the only number of fans my casing can connect too and Idk if my psu can handle more fans. maybe it can. it's a non-modular SST-ST60F-ESB @ 600w and my mobo is  a Gigabyte GA-F2A58M-DS2
So this is a great little case that I have built 2 systems in, one for my wife, another for a family friend. This has lots of space for fans so you can add additional fans
https://www.newegg.com/Product/Product.aspx?Item=N82E16811139068&cm_re=corsair_88r-_-11-139-068-_-Product
1 minute ago, Belbs said:
what's a good cheap PC Casing? Idk what brands are good. I need a new casing with better airflow as my current one heats up my parts way too fast and it worries me. I prefer one that supports a micro-atx form factor mobo. thanks!`
What case do you have right now? How many fans are in the case and how is your air flow? Can your case and motherboard/power supply support additional fans in the case to move air around?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Community Standards
"Beast Mode"
thanks man I'll check it out :D thanks!
