i am going to custom build a sff case and will use this as power button
http://www.ebay.com/itm/232209722389
will it work ? and do i need to supply my own wires to connect it to the header (asked the seller but he doesn't know) if so can i use something like these wires after removing the button ? (already have some in hand)
http://www.ebay.com/itm/ATX-PC-Computer-Motherboard-Power-Cable-Switch-On-Off-Reset-with-LED-Light-/381468583706
https://linustechtips.com/topic/749665-question-about-modding-a-power-button/
yeah it will work, power button is just shorting 2 pins, nothing special :)
and no you don't need your own wires :)
Quote
what do you mean by this?
i mean will it come with it own wires to connect to the motherboard header since there is no wires in the photo
what do you mean there are no wires in the photo?
the one you linked definitely has the  headers and wires :)
this is the one i want to use with my case
i dont see wires here
ooo i was looking at the bottom link, yeah you can just solder the power button to the wires on the other switch :)
follow the instructions on this video, but instead of using sata power cables, connect the two wires coming off the power switch header:)
i see
thank you
Yes, as long as they work as button do, they will work. The power button is just an element to close the circuit so the power can run. And obviously you have to wire it from each 1 pin to the + power pin and 1 pin to the - power pin (It doesnt matter which pin you connect with each pin, you only have to close the circuit!).
31 minutes ago, oldnick said:
will it work ?
"Momentary push button" is exactly what you need. Other specs shouldn't matter as I cant think of a momentary button that would not work. I can see on ebay some listings are using the word "tactile" which appears to be the same as momentary, just avoid "latching" switches.
yep those will work. I cant see anything wrong with your plan.
TLDR: as long as you dont try putting your "oldnick" into it, it will be fine
ψ ︿_____︿_ψ_
