Hi guys,
I was wondering if you could help me out. My son has just got into gaming; he wants to start playing overwatch but sadly his laptop that he is playing on can barely run battlefield 2 so its time to upgrade him. Sadly i only have a very small budget.
Budget: $400 (Australian Dollars)
Must be able to run overwatch and csgo.
extra information: I have  2x r9 270 so no need to get a graphics card.
Kind regards
Annie
I am happy little Vegemite.
https://linustechtips.com/topic/749631-sons-first-computer-need-help/
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($72.00 @ Shopping Express)
Motherboard: MSI B250M PRO-VH Micro ATX LGA1151 Motherboard  ($109.00 @ Mwave Australia)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($67.90 @ Shopping Express)
Case: Antec VSK3000B U3 MicroATX Mini Tower Case  ($45.00 @ IJK)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($89.00 @ PCCaseGear)
Total: $382.90
Generated by PCPartPicker 2017-03-09 17:18 AEDT+1100
Pick up a cheap used HDD from somewhere. CPU is essentially an i3 6100 with 200Mhz less for half the price, and mobo is expensive asf but it's just for compatibility with the processor since it's on a new architecture. 550W PSU is very good quality and is probably enough for both GPUs in crossfire :P
idk
If you can re-use the hard drive from the laptop, this fits your budget:
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($72.00 @ Shopping Express)  <<2 core/4 thread, like an i3 but cheaper
Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard  ($116.00 @ IJK)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($75.90 @ Newegg Australia)
Case: Zalman R1 ATX Mid Tower Case  ($55.00 @ Mwave Australia)
Total: $407.90
Generated by PCPartPicker 2017-03-09 17:19 AEDT+1100
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($72.00 @ Umart) find out if the bios supports kabylake processors.
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($60.00 @ Shopping Express)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($85.00 @ Shopping Express)
Total: $401.90
Generated by PCPartPicker 2017-03-09 17:20 AEDT+1100
