More C++ Problems
Go to solution Solved by CookieMaster,
Thanks all that helped, I have finished and tested and all works fine.
What's the error you're getting? I haven't used C++ myself, though I have used Java quite a bit (They're similar), so I might be able to help.
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488149
expected a statement. I have a feeling I know what the problem is and maybe where but I just can't think :/
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488155
14 minutes ago, CookieMaster said:
Thanks, that fixed it, I knew i was missing something like that.
The {} brackets really help with organization. Your indentation was off because you didn't have the brackets. Therefor, the compiler was looking at your else if statements as part of the original conditional statement.
Good luck on the rest of it!
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488247
I recommend for any programming language that normally requires curly braces to create a new scope, use it even if it allows things like omitting them for single line if-statements, for-loops, or while-loops. Mostly so you don't run into this issue again.
If people get annoyed by
if (something)
	//Do something that requires one line
They have nothing better to do with their time :B
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488284
43 minutes ago, CookieMaster said:
Yeah I feel stupid asking, but still new to C++, what am I missing and where. Thanks (the error is on both else's)
if (choice == 1)
	cout << "Enter a file name." << endl; // Have end user input a file name
	cin >> filename;
	ofstream outFile((filename + extension).c_str()); // Get the file name and add extionsion to it.
	outFile.open(filename);
	 else if (choice == 2)
		cout << "It appears the programmer has not coded this part in" << endl;
	 else if (choice == 4)
		cout << "Hello" << endl;
Also note that ofstream's constructor will open the file so the extra call to open is redundant. Since C++11 the constructor also accepts a std::string reference, which is the preferred choice.
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488347
if (something)
Thanks
Thank you for letting me know.
And now I have a diffrent problem in which I'm not understanding. On lines 28 and 42 its saying
Error    C3867    'std::basic_ifstream<char,std::char_traits<char>>::is_open': non-standard syntax; use '&' to create a pointer to member    (replace ifstream with ofstream for other error)
Here's my code now
#include "stdafx.h"
#include <iostream>
#include <fstream>
#include <string>
using namespace std;
int main()
	int choice;
	string filename;
	string type;
	cout << "*****Welcome To PACS!*****" << endl << "Choose An Option:" << endl; // The basic display of the program.
	cout << "[1] C-STORE" << endl;
	cout << "[2] C-FIND" << endl;
	cout << "[3] C-GET" << endl;
	cout << "[4] C-ECHO" << endl;
	cout << "[5] Exit" << endl;
	cout << "Enter choice [1-5]:" << endl;
	cin >> choice; // Get user input into an int.
	// The if statements to make the program work.
	if (choice == 1)
		cout << "Enter a file name." << endl; // User needs to put a file name to search.
		cout << "Enter a file type.(Must have a . in the front" << endl; // Have user put in type.
		cin >> type;
		ofstream outFile((filename + type).c_str()); // Get the file name and add extension to it.
		if (outFile.is_open)
		outFile.close();
		cout << "It appears the programmer has not coded this part in." << endl;
	else if (choice == 3)
		cin >> filename;
		cout << "Enter a file type.(Must have a . in the front." << endl; // Have user put in type.
		cin >> type;
		ifstream File((filename + type).c_str()); // Get the file name and add extension to it.
		if (File.is_open)
			getline(File, type);
		File.close();
    return 0;
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488434
Oh, I also thought of a practical reason why to add curly braces your if-statements and loops all the time: if you need to expand it, you don't have to remember to add the curly braces.
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488455
Here's my code now
#include "stdafx.h"
#include <iostream>
#include <fstream>
#include <string>
int main()
	int choice;
	string filename;
	string type;
	if (choice == 1)
		cin >> type;
		outFile.close();
		cin >> filename;
		cin >> type;
		if (File.is_open)
		File.close();
    return 0;
is_open is a member function, you need to add () to function calls:
if (outFile.is_open())
There's also no need to manually call close. When the ofstream object goes out of scope it's destructor will close the file automatically.
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488521
Thanks I removed that, and that's what I thought the problem was. Silly me kept putting )()). Plays with your eyes a bit I guess.
https://linustechtips.com/topic/749462-more-c-problems/#findComment-9488557
