Need advice on CableMod for a be quiet! DPP PSU
Xiphan
Go to solution Solved by CableMod,
13 hours ago, Xiphan said:
So I want to get some cables from @CableMod but I am a bit confused about my PCIe requirements. While using the configurator to choose just the cables I will need for my build I came across the following option: Dual 8 Pin PCI-E. Since I have a Fury X which needs two 8-pins can I just get one of these and will my PSU (be quiet! Dark Power Pro 10 750W) be able to supply enough power to the card from only a single cable? o.O
Hey @Xiphan you should be perfectly fine to run a dual PCI-E cable. :)
If it has 2 8 pin PCIe connectors, then yes, that will be 100% adequate.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
No you need both 8 pin for Fury
