Graphics Issues?
Go to solution Solved by SorcierX,
The fact it just randomly shutdown and then wouldn't power the graphics card, leads me to believe it's got nothing to do with the extender.
Does this board have onboard video?
If so, remove the gpu, and try booting using onboard.
If no, buy a new psu, take it out of the packaging carefully try it.
If it works, keep the psu, problem solved.
If it doesn't, pack the psu back up and send it back.
My $0.02
So, I purchased this PC as a prebuilt (helpful comments only, please) about a year and a half ago. Today, I was booting Steam, and it just turned off on me, no warning.
When I tried to reboot it, it turned on, but the monitor still said no signal. The GPU fans weren't spinning either, so I assume it's a graphics issue, but is there anything else it could be?
(If there are any fixes not involving buying a new GPU, they'd be appreciated) :)
Specs:
AMD Athlon 860K
R7 370
Some kind of Gigabyte A88X motherboard (I have the manual somewhere)
The worst gamer, in the world
Still haven't got past the first world of Super Mario Galaxy 2
https://linustechtips.com/topic/748872-graphics-issues/
I considered the PSU being dead, and it is most definitely shitty.
Also, is there a possibility it's something to do with it being run off an outlet extender?
Edited by SamwiseDB
https://linustechtips.com/topic/748872-graphics-issues/#findComment-9481814
My $0.02
AsRock X99 Taichi MB // Intel Core i7-6800k Overclocked @ 4.0GHZ // Noctua NH-U14S Cooler // Corsair Vengeance LPX 16GB DDR4 // EVGA GeForce 980Ti SC+ // Samsung 850 EVO 500GB SSD // 2TB WD Gold HDD // Corsair RM850 PSU // Corsair Obsidian Series 750D // Asus VG248QE 144Hz
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 // Intel Core i5-3570k Overclocked @ 4.2GHZ // Noctua NH-L9x65 Cooler // Corsair Vengeance 16GB DDR3 // EVGA GeForce 960 // 250 GB WD Blue HDD // EVGA SuperNOVA 650 G3, 80+ GOLD // Corsair Carbide Series 100R
https://linustechtips.com/topic/748872-graphics-issues/#findComment-9481874
