I'm going to buy the ek-kit x360, but I have a few questions before.
1) Can I add an extra radiator to it. Like get the whole kit, but once it gets home add an extra radiator to it.
2) Can I change the tubing to a red colored tubing.
 a) if so can you recommend me one that fits the kit.
3) Is there a dye I can buy here to change the color of the water?
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/748518-watercooling-help/
1. Yes you can add another radiator, but you would need extra fittings
2. You can change it, as in you buy separate tubing that is red
3. You can dye your water. There are a lot of people who might say that coloring your water isn't the best for you, but there are also a lot of people who disagree with that. So long story short, yes.
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477871
Thanks so much for your reply, I honestly appreciate it a ton
1) Okay I was thinking of a loop sort of like this
Resevoir to pump to radiator 1 to gpu to radiator 2 to cpu to reservoir. How does that sound?
3) Can you suggest any dye things? (red please)
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477889
so rad 1 goes to the cpu from the top rad mount then that water goes through a rad on the back of the case, then to the gpu, then to the pump?
A8-7600 {} Gigabyte FM2+ Board {} CX430 {} Corsair Vengeance LP 8gb {} MSI GTX 760 2GB {}
Console.WriteLine("C# is aids");
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477909
That loop sounds good. You can buy straight up red coolant that you don't need to dye like this: https://www.ekwb.com/shop/ek-ekoolant-evo-blood-red-premix-1l
Also for red tubing you can get something like this: https://www.ekwb.com/shop/tube-primochill-primoflextm-advanced-lrttm-12-7-9-5mm-bloodshed-red-retail-3m
But you really only need one or the other. It would be redundant to have red on red.
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477912
The loop order doesn't matter really as the fluid moves around the loop so fast, personally I would recommend the P360 kit since it has the better D5 pump.
As for dyes or colored fluids Mayhems would be one of the best out there, for transparent fluid their X1 series would be perfect.
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477932
rad 1 (front) goes to gpu, from gpu it goes to rad #2, from rad #2 it goes to cpu, then reservoir and pump
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477963
Yes, I just finished a kit on ekwb for $830. I'm pretty happy with the selection.
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9477965
Well I have completed the research for the watercooling loop. Now I just ask for which one I should buy.
For #1 we have the ekwb kit x360. If I do get this ill add a gpu block and an extra radiator. ( https://www.ekwb.com/shop/ek-kit-x360 )
For #2 we have a custom loop I designed to fit my pc needs.
http://prntscr.com/egw3cd
http://prntscr.com/egw3in        Radiator 2
http://prntscr.com/egw3o4
        CPU
extra information :
My loop will be,  like this  (To the right)
        Resevoir
        GPU               Pump
        Radiator 1
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478047
how my loop will be : http://prntscr.com/egw7hu
Extra info for #2 (VERY IMPORTANT TO READ) : http://prntscr.com/egw85q
http://prntscr.com/egw8b5
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478053
For the second option you might also want a bracket to mount the pump.
https://www.ekwb.com/shop/pumps/d5-series/holders-brackets
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478084
9 minutes ago, Ultra_Man52 said:
That custom loop is very very expensive, the kit is so much cheaper.
Yea but I will most likely be doing extreme overclocking
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478110
which one do you suggest
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478114
Depends on where you want to mount your pump. You have the Phanteks Enthoo Pro? If 'm correct you have space at the bottom for 2 120mm fans, or 1 140mm fan where you could mount the bracket.
So each one should do.
I would probably go with this one. https://www.ekwb.com/shop/ek-uni-pump-bracket-120mm-fan-vertical
https://linustechtips.com/topic/748518-watercooling-help/#findComment-9478148
