I am going to build a pc with i7 7700k and rx 480. Case is corsair 100r silent edition. Summer temps are around 35-38 degrees celsius. Do i require air conditioning for my pc to perform? Or is it okay without it? Also, will my room get hotter? I will keep the case beside the monitor.
https://linustechtips.com/topic/748213-do-i-need-air-conditioning/
if your room gets above 30c, I would recommend an AC in there personally..
Community Standards
"Beast Mode"
Dedicated Streaming Rig
For me any thing above 20 is too hot so i would say yes, you should get air conditioning. Plus your PC will potentially make the room slightly hotter.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
Its best to buy a brand new window air conditioner, dont skimp out buy one that has a high BTU rating something in the range of 7500+ BTU ac. I left mine on 24/7 but my condo was on the main floor of a 3 level, and in the corner with no sky sight. In the winter I'd rarely if ever turn on the heat, but I like my cribs cool. I personally sleep with a fan on 24/7, even right now at 2:30am I got the fan on low, its about -5C out right now with a light snow. I can feel the heat at my feet from the vent 3' away under my desk.
I have an ac in the bedroom, but i was planning to keep my pc in the living room, where there is no ac. So should i keep it in the bedroom? And whenever i use it should i switch on the ac?
yes a 7700k puts out a significant amount of heat currently i'm using it as a space heater in my basement and this is during the winter the cpu should be fine as long as you get a good cooler the 7700k runs really hot so as long as you get a really good cooler you the computer should be fine but you'll probably be dieing in the heat.  get a ac or get ready to sweat
Yes, the system will produce heat.
Whether you need air conditioning or not depends on how good your system cooling is.
