Seeking hardware based remote desktop solution
Go to solution Solved by Droidbot,
IPKVM?
I'd need to describe carefully what I'm after... then, let's see if it exists or not.
I want to control a PC "B" from PC "A". I want the experience to be like I'm sitting directly at PC "B" but I would like it in a software Window on PC "A" (not full screen), so that rules out traditional KVMs. Why not software remote desktop solutions? I need access outside booting OS also e.g. if I need to change bios settings. So it would be some kinda software/hardware KVM hybrid, needs to emulate keyboard and mouse, and capture and transfer video signal.
The two PCs would be in the same general area as each other so I'm not bothered on the physical connection method.
IPMI is probably what you're looking for, however as a hardware solution it requires (surprise surprise) specialised hardware - a motherboard with onboard IPMI module and a dedicated LAN port.
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
Just now, Droidbot said:
IPKVM?
Knew it must exist, but can't search for it without knowing what it was called. That's perfect, looking up a suitable model now :)
1 minute ago, Name Taken said:
Sounds like you're describing IPMI.
Close, but not quite.
