i have a corsair 400c and im looking to fill it it with rgb led fans and potentially some light strips im wondering whats the best fan and controller combo for a decent price
the case has 6 120mm fan slots which i would like to fill with led fans
i have no prior experience with rgb fan/light strip controllers
https://linustechtips.com/topic/747613-rgb-led-setup-help/
The best looking fans are the Corsair HD120's.   But they are a pain in the arse (no software management).
The best management at the minute still seems to be the NZXT HUE+ with the AER 120 fans and lighting kit.
I dont like the AER as much as the HD120's (i have both) but they are good enough.
https://linustechtips.com/topic/747613-rgb-led-setup-help/#findComment-9467763
any advice as far as a controller that would accept both the fans and any led strips i might wanna add?
https://linustechtips.com/topic/747613-rgb-led-setup-help/#findComment-9487912
