Vinyl wrapping a mouse?
Go to solution Solved by MeDownYou,
On my mouse it worked, with 1 issue I had to take my mouse apart in order to wrap it, and I'd go with matte vinyl as gloss feels really slick and then your hand sticks to it.
10 minutes ago, WowMuchName said:
Like it says, would it be possible without peeling? And I mean, I can always replace it every year or something if I have to, but yeah.
It's definitely possible, give me a bit and I'll attempt it on my cutter real quick
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
https://linustechtips.com/topic/747370-vinyl-wrapping-a-mouse/#findComment-9465051
https://linustechtips.com/topic/747370-vinyl-wrapping-a-mouse/#findComment-9465154
Thanks! Sorry it took me a while, I forgot about it :P
https://linustechtips.com/topic/747370-vinyl-wrapping-a-mouse/#findComment-9472150
