There are some results on the second half of the page here:
http://www.hardware.fr/articles/956-16/rendu-3d-mental-ray-v-ray.html
In these results, AMD Ryzen 7 1800x performs very slightly faster (about 2% lower render time) than an Intel i7 6900K, and quite significantly faster than Intel i7 7700K (render time is about 33% lower with Ryzen).
I'm not sure about the Ryzen 1700K though.
Best regards,
Vlado
https://linustechtips.com/topic/747082-3ds-max-cpu-vray-bench/#findComment-9464521
  • 9 months later...
Best regards,
Vlado
Have you set up your PC? I'm also in doubt, which is the best
https://linustechtips.com/topic/747082-3ds-max-cpu-vray-bench/#findComment-10822309
