Hey folks! It's me again. lol
This time though, I need help with finding that sweet spot case. Right now it's between 3 cases. The first being the Corsair Carbide Clear 400C Compact Mid-Tower Case, the second is the Thermaltake SUPPRESSOR F31 ATX Mid Tower, and then finally the MasterCase 5 Mid-Tower Computer Case.
I chose these 3 cases as the options, because I like that they have a side window, and because they all seem to have very good reviews. Originally I was going to go with the cheaper Corsair Carbide Spec-01. My main concern is, this being my first computer build, I have no concept of cable management in this type of thing. Another thing I'm wondering about is case modularity. Is a modular case just outright better than a normal case?
Thanks again in advance for all the help!
https://linustechtips.com/topic/745503-case-help/
personally I would go with the MasterCase 5. Cooler master has a pretty good rep with cases, looks great, and you should be able to fir just about anything in there without a problem
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/745503-case-help/#findComment-9443931
i would personally go for either the corsair or cooler master case.  both are amazing cases but cooler master might edge out in this one due to its flexabilty especally for a first time user
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/745503-case-help/#findComment-9443940
Cool. Also, as a follow up question; Is cable management that difficult? I know it's probably pretty straight forward, but would you recommend a semi-modular power supply to help with it? Or is the Cooler Master case pretty good with not need too much OCD with cable management? ^^;
https://linustechtips.com/topic/745503-case-help/#findComment-9443987
depending on the power supply you have now and how much stuff you have to power you shouldn't need one. The Coolermaster case has pretty good cable management. I would just get some more zip ties (they never give you enough)
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
https://linustechtips.com/topic/745503-case-help/#findComment-9444013
Awesome! Sounds like I've found the last piece that I need for my PC puzzle. Thanks! :D
https://linustechtips.com/topic/745503-case-help/#findComment-9444040
