PCI wifi card
Solved by jared404,
Just now, Andooo said:Thank you so much dude! What classifies good though? How would they each compare to an ethernet connection?
You will get more reliability with the good one and possibly better driver support. Speed will vary slightly between them. The good one will have better reception if it is further from the router. Both of them will let you upgrade the antennas if you need better reception. They both use standard sma connectors for the antennas
