I know only a bit in building pc, so I'm having trouble in making one.
https://pcpartpicker.com/list/j4bnM8
Is this build good? I'm trying to keep it under $950 - $900. I'm a gamer, and I also like to multi-task. A friend of mine told me that I should invest more on gpu, cpu and ram and keep it "balanced" to avoid bottlenecks. I already have storage and some periperals so no problems about that. Any suggestions, opinions, and helpful criticism would be nice :D
https://linustechtips.com/topic/744944-first-time-in-building-need-help/
don't get an aftermarket heatsink and z170 mobo on a locked i5. also the psu is mediocre.
CPU: AMD RYZEN 7 1700 3.0GHz 8-Core Processor  ($329.99 @ B&H)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory  ($86.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.00 @ Jet)
Case: Azza SIRIUS ATX Mid Tower Case  ($19.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($47.89 @ Newegg)
Other: MSI B350M Gaming PRO AM4 AMD B350 SATA 6Gb/s HDMI Micro ATX Motherboards - AMD  ($81.98 @ Newegg)
Total: $945.84
Generated by PCPartPicker 2017-02-27 22:35 EST-0500
Total: $945.84
just a note: don't buy shit until reviewwers release hard facts and real metrics
idk
or this if you want it now
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($299.99 @ SuperBiiz)
Motherboard: Asus H110M-E/M.2 Micro ATX LGA1151 Motherboard  ($46.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($379.99 @ Jet)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($37.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $961.26
Generated by PCPartPicker 2017-02-27 23:01 EST-0500
idk
hey what about this build? https://pcpartpicker.com/list/Dkq3BP
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($196.33 @ OutletPC)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler  ($37.88 @ OutletPC)
Motherboard: MSI B250 PC MATE ATX LGA1151 Motherboard  ($94.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2800 Memory  ($94.99 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($64.99 @ SuperBiiz)
Power Supply: Corsair RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.90 @ Newegg)
Total: $997.41
Generated by PCPartPicker 2017-02-28 14:06 EST-0500
6 minutes ago, Twirl Yourself said:
I might also consider overclocking it, so, should I need cpu cooler? Or would the stock heat sink be enough?
Overclocking adds significant cost to the build. You should get an unlocked cpu (ends in K) and a Z170 or Z270 motherboard. As well as a decent aftermarket cpu cooler.
OC on the two intel builds is impossible, OC on the Ryzen build is possible BUT you will need a basic CPU cooler like a Hyper 212 EVO or GAMMAXX 400
idk
for intel if you're getting an unlocked cpu you will require an aftermarket heatsink if you're getting a locked cpu like the 6700 and 7500 listed you won't be able to overclock. you'll have to wait for reviews on ryzen's heatsink but judging from the older wraith cooler it should be enough for a mild overclock.
