CPU Temps curiosity with Node 202
Go to solution Solved by flibberdipper,
It's normal. Hell my Pentium is cooled by an H115i (212 EVO couldn't tame it and #FutureUpgrades) and my lowest idle temps are in the high 20s with loads in the high 50s.
First of all, hi everyone and thanks in advance,
my name is Marco and I decided to build the second computer of my life and I'm having a question about CPU temperatures. Here are the specs, so that I can explain better later on:
Case: Fractal Design Node 202 with Integra 450W PSU;
Motherboard: Gigabyte Ga-H270N-WiFi;
CPU: Intel i5-7500;
CPU Cooler: Cryorig C7;
RAM: 1x8GB Crucial Ballistix Elite DDR4;
SSD: Crucial MX300 M.2 Sata, 275GB;
HDD: Hitachi Travelstar 1TB 2.5 7200RPM;
Graphics Card: Gigabyte Geforce GTX 1060 6GB Windforce
Fans: Two Fractal Design 120mm PWM fans. Sorry I can't remember the name.
I think that's all. So now, I want to describe the "problem" that I have. I'm having higher CPU temps than I was expecting with an aftermarket CPU Cooler. AIDA64, at idle, gives me a reading of around 34°C (about 93° F). Now, I know that this is not that bad and I know that the case is actually really small so temps can be tricky to handle, but, still, given that I have something like 20°C (68° F) in my room I think that it's too high. I checked the CPU Cooler and it's not moving or anything (of course the fan is moving, I mean the actual cooler is sitting still over the CPU) and I think I applied the right quantity of thermal paste (the one provided by the CPU Cooler). Cable management is as good as it can be in such a tiny case. I tried to run AIDA64 stress test for 10 minutes and the max temperature that I got was 57°C (134°F). That, again, is not disastrous, but higher than what I was expecting. GPU temps are actually pretty good, so no problem there. Is there anyone that can explain such readings? Am i being paranoid for no reason? Sorry if I made any mistake but I'm actually Italian, so my English might be not perfect. If this is a silly question I'm sorry. Thanks again, I hope someone can give me an advice.
https://linustechtips.com/topic/744686-cpu-temps-curiosity-with-node-202/
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I have a huge tower cooler and a big case and good ventilation, but my temps are very similar, about 30 C idle and 60-70 while gaming
You are fine
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
