Planning to build a pc with these specs.
Intel Pentium G4560
1*8GB DDR4 2133 MHz RAM
GTX 1060 3GB
Antec BP450PS PSU
Gigabyte H110M-S2 Motherboard
WD Blue 1 TB HDD
Samsung 120GB SATA 3 SSD
Should I upgrade the CPU to a i3 6100 instead?I am on a tight budget here. I  am looking for 1080p Gaming at high setting over 60FPS
https://linustechtips.com/topic/744517-build-advice/
Intel Pentium G4560
GTX 1060 3GB
Antec BP450PS PSU
WD Blue 1 TB HDD
That psu isn't good
G4560 won't work with that board w/o bios update so get i3 6100 or get a b250 mobo
Cheaper ssd?
Get rx 480 4gb over 1060 3gb
https://linustechtips.com/topic/744517-build-advice/#findComment-9432945
