I found a monitor laying around and decided top add it to my current set up, but nothing is showing up on the screen. It is connected via DVI (though a vga adapter). The computer picks up that there are three monitors but the screen says "There is no signal coming from your computer. Press and key on the keyboard or mouse to wake it up"
Again the computer picks up the third display and even says the monitor type (a DELL E170S).
I have made sure my graphics card can do three monitors and it can (it can go up to 4). The graphics card is a
"GIGABYTE GeForce GTX 1050 Ti DirectX 12 GV-N105TG1 GAMING-4GD 4GB 128-Bit GDDR5 PCI Express 3.0 x16 ATX Video Card"
and it is updated to the most recent driver.
I don't know if there is a setting im just overlooking or what
Fixed:
My adapter (vga male to dmi female) did not work so I just went with a hdmi to vga. Works fine now
Edited by DevilsHand676
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/743672-setting-up-3-monitors-help/
Did you select the right input on the monitor?
yea the monitor only has one input, a VGA
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
whats odd is that when i move the mouse over to where the third monitor is it disperses (like it is going to the other monitor
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
Did you try the monitor by its self to see if it is working?
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
yes I tried the monitor on another computer and it worked fine
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
Ninja'd.
Main Rig:-
Server:-
was that with or without the display adapter?
huh yea just tried to use it with out the adapter (on a different pc) and it worked. guess my adapter is busted :(
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
If possible, try the adapter with another working monitor/cable/computer to make sure but that sounds like that is the case.  I don't know much about adapters, I know some need to be active/passive but I'm not sure which.  Did the adapter work before?
no i just got the adapter today from the store, I am going to return it got a male dvi to female vga (i had male vga to female dvi) idk maybe that will work
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
