I can't personally recommend a cooler for you but you can use this link and set the height slider to 100mm max
http://pcpartpicker.com/products/cpu-cooler/
Desktop Rig:
CPU: i7-6700K  Cooler: Noctua NH-L9x65  Graphics card: NVIDIA GeForce RTX 2080 Ti FE  Memory: Corsair VENGEANCE LED 3200Mhz (2x8GB)
Motherboard: ASUS ROG STRIX Z270i  SSD: Samsung 960 EVO 1TB, Samsung PM981 1TB  Case: Louqe Ghost S1
Monitor: Dell Alienware AW3418DW
https://linustechtips.com/topic/741966-cpu-cooling/#findComment-9404965
15 hours ago, kylejohns said:
thanks for the help really appreciate it, would this cpu cooler https://www.amazon.com/dp/B003INFE16/?tag=pcpapi-20
work for a i7-6700k?
or will it no t give enough cooling cause i see that you have yours water cooled?
The Vortex Plus isn't great and would barely keep up with the 6700k at stock speeds.
What case do you have and what's your budget?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/741966-cpu-cooling/#findComment-9410359
i have a b150 pro gaming and a cit geforce case
https://linustechtips.com/topic/741966-cpu-cooling/#findComment-9410940
What's your budget?
Why are you looking for coolers under 100mm? The case supports coolers up to 161mm in height.
https://linustechtips.com/topic/741966-cpu-cooling/#findComment-9411004
